May 23, 2023, 09:42 |
DPM water injection
Italy
Rep Power: 4 |
Hi everyone, i'm trying to simulate water droplet injection inside an air ejector. I created an appropriate surface on ICEM, and i want to inject water droplets from that surface. Once i've created the DPM injection in Fluent, it asks me to give both velocity and total flow rate. How they are connected to each other? In particular, how is this total flow rate defined? Because i want to inject 0.46 kg/s mass flow of water, but i don't if this total flow rate is exactly what i want to inject.
Thanks. |
May 24, 2023, 05:27 |
Alain Islas
Rep Power: 6 |
Hi Alessandro Lamberti
Be cautious with velocity and mass flow rate, these are independent parameters. Keep in mind that in DPM, the mass flow rate is NOT a continuous mass flow rate (i.e., m_dot = rho*A*velocity is not valid). In DPM, the mass flow rate is discrete, and has nothing to do with the velocity that you input in the setup panel. For the DPM mass flow rate calculation, you can refer to any of my old posts in the Ansys Fluids Forum https://forum.ansys.com/forums/topic...ion-speed-m-s/ https://forum.ansys.com/forums/topic...tal-flow-rate/ https://forum.ansys.com/forums/topic...les-injection/ https://forum.ansys.com/forums/topic/regarding-dpm-2/ |
May 24, 2023, 05:34 |
Italy
Rep Power: 4 |
Thank you alainislas, as i can see you have defined the massflowrate as the number of particles injected per second multiplied by the mass of the single
particle. This is ok using a transient simulation, but what is the number of particles injected per second if i use a steady state simulation? Is it the number of cells of my surface? (Because i'm using a surface injection type and i have like 900 cells in that surface). |
May 25, 2023, 05:16 |
Alain Islas
Rep Power: 6 |
For surface injection, typically Fluent injects one parcel per cell face. If your surface has 900 then it will inject 900 parcels. However this change if you are injecting a PSD with various diameters. It will also change if your parcel release method is other but "standard". Please consider that, for steady tracking, a stream of identical particles is tracked through the domain. This stream initially has a mass flow rate associated with it, although it may change during the tracking due to chemical reactions if enabled (evaporation, devolatilization, combustion, etc...). In contrast, when unsteady tracking is used the particles are represented by parcels that correspond to an ensemble of identical particles. Parcles do not have an associated mass flow rate, but rather have a specified mass (at the time of injection into the domain).
UDF for DPM modelling to simulate ammonia absorption into water droplets | Jack0210Jack | Fluent UDF and Scheme Programming | 9 | December 28, 2023 01:36 |
Cone injection in DPM | kaveh0a | Fluent Multiphase | 13 | May 13, 2020 16:36 |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 14:27 |
file injection.: continuity fail; volume injection.: wrong total mass | blerli_91 | Fluent Multiphase | 6 | October 2, 2018 05:34 |
Injection of water in vapor | SimoneTecnoil | FLUENT | 0 | November 9, 2009 11:29 |
