Solving tracer homongenization in a stirred vessel
Old   May 6, 2023, 05:20
Default Solving tracer homongenization in a stirred vessel
Aloha
HWIK is on a distinguished road
Hi, I am trying to compute the mixing time in a stirred vessel, I am modelling this in Fluent using MRF and SM approaches. For the MRF, given it is a steady state method, after resolving the flow profile in steady state, I just initialised the data in the vessel with that result and solved the tracer diffusion equation only, and not the flow equations in a transient simulation to predict the the change in concentration over time.
I want to do something similar with the sliding mesh, I have the flow profile resolved, could I then use a similar approach to tracking tracer difusion in the stirred vessel? So, turning of tracer the solution for the flow equations and only solving the tracer equation?
HWIK is offline   Reply With Quote
Old   May 6, 2023, 16:33
NickFL is on a distinguished road
With a sliding mesh approach, you will have to solve for the flow equations too. That is unless you have an unbaffled tank where the time-averaged and each instantaneous flow field is the same.
NickFL is offline   Reply With Quote
mixing impeller, mrf vs sm, sliding mesh, tracer, tracer injection
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
