Inquiry: What best number of USP cores can be utilized? |
May 5, 2023, 10:36 |
Murtadh
Rep Power: 3 |
Hi every one
My PC with the following hardware : 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz / 24 core(16 E core, 8 Pcore) 64.0 GB DDR5 RAM 6000 NVIDIA GeForce RTX 3060 when I ran calculation for the model of about 8000000 mesh elements in Ansys 22 with 32 core and utilizing GPU , the calculation process and post processing program stooped suddenly ! after rerun the calculation with also 32 cores but with 0 GPU , THE CALCULATION TAKE A VERY LONG TIME - what is the best number of cores can I utilize, and what is wrong with GPU. Note: with the less density mesh like 4000000 element the GPU run normally , there is no prop. with GPU itself. Thanks in advance |
mesh 3d, mesh acceleration, mesh and grid, mesh around holes, usp cores |
FOAM FATAL IO ERROR:file: unknown | YatengQ | OpenFOAM Running, Solving & CFD | 0 | January 31, 2023 08:14 |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 19:32 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 10:15 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 09:14 |
decomposePar pointfield | flying | OpenFOAM Running, Solving & CFD | 28 | December 30, 2013 16:05 |
