May 5, 2023, 07:48 |
fluent+steady state thermal
Yakub
Rep Power: 3 |
https://drive.google.com/file/d/16Ua...ew?usp=sharinghttps://drive.google.com/file/d/1FMROhfjiimoeffroUM2rj2X8bXxPOp7D/view?usp=share_link https://drive.google.com/file/d/1TTJ...linkSubscriber
Hi, I have tried to solve one steady state thermal problem along with fluent by coupling them. Heat generation is given as boundary condition and convection value is successfully imported from fluent which is already solved in workbench.But during solving in thermal, after 80%+ it shows one error "An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports. Please see the Troubleshooting section of the Help System for more information" .Please help for the same. [IMG] Last edited by YAKUB A; May 5, 2023 at 07:52. Reason: image not visible |
[Other] Mesh Generation inside Steady State Thermal program | sasanghomi | ANSYS Meshing & Geometry | 0 | June 1, 2020 02:43 |
The difference between steady state and transient | JuPa | CFX | 36 | December 9, 2019 22:50 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
