Hypersonics CFD simulation of Re-entry Vehicle ERROR |
May 4, 2023, 14:49 |
Claudio
Rep Power: 5 |
Hi everyone,
I am trying to simulate the flow around a hypersonic vehicle to compute its Cd and Cl. The domain is a cylinder, with pressure-far-field BC on the inlet and pressure-outlet on all the other faces of the cylinder. The vehicle is simply modelled as a wall (cut-out from the domain), with prismatic layers to model the Boundary Layer. I am using the density-based solver with steady-state conditions, energy on and SST K-omega viscous model. The fluid is modelled with ideal gas for the density, constant Cp and Sutherland's law for viscosity. The problem is that when I run the simulation for Mach 2-4 I obtain reasonable values for the Cd and the residuals decrease down to ok-ish values (unfortunately continuity does not seem to go below 1e-2, though the Cd does not vary any longer over a large number of iterations). However, when I change the Mach number to 5 or more for the inlet pressure-far-field BC, the residuals diverge within a few hundred iterations and lead to a floating point exception. Are there any other changes I need to make to change the flow from supersonic to hypersonic? Are there any problems with my set-up, or is it just a problem due to the mesh? |
cfd, error, hypersonics, mesh, set-up |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
