May 4, 2023, 11:25 |
2D Axisymmetric Swirl simulation
Rep Power: 10 |
Dear all,
I'm now conducting a 2D multiphase flow simulation with Axisymmetric Swirl settings. I have an surface injection for this case (maybe point injection also works), while I found that there are three velocities to be set: X-velocity, Y-velocity, and Z-velocity. Could anyone tell me if the Z-velocity in the injection is the same thing as the 'swirl velocity' at the velocity inlet boundary? And is the X/Y-velocity the axial/radial velocity? I doubt if I was right, because when I set Z-velocity to 100 m/s, and then tracked the particles, I found the swirl velocity of the injected particles was only 40m/s near the injection surface. Many thanks!!! |
Simulation of swirl atomizer using VOF | HengLiu | CONVERGE | 3 | December 29, 2021 11:12 |
Results of an axisymmetric simulation in Fluent | ShimiSan | FLUENT | 0 | July 19, 2016 09:20 |
Axisymmetric Swirl | Arpit Tiwari | Main CFD Forum | 1 | September 15, 2010 05:45 |
Axisymmetric swirl CHT with MRF | Jonathan | FLUENT | 0 | September 30, 2008 04:53 |
2d axisymmetric with swirl | heather | OpenFOAM Running, Solving & CFD | 5 | July 28, 2005 17:20 |
