May 4, 2023, 10:54 |
Fluent CHT
Davide
Rep Power: 10 |
I would make a simulation in Fluent with the conjugate heat transfer between a fluid and a solid domain. What is the option to set correctly the interface between the two domain? I have tried with the coupled wall option, however in the post I see that the two sides of the interface share the same heat flux, while the temperature are different, why? Thank you Davide |
[Commercial meshers] Unknown error when converting fluent mesh to openfoam | Yutao | OpenFOAM Meshing & Mesh Conversion | 0 | April 23, 2023 02:30 |
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate | Kieyo | Fluent Multiphase | 0 | November 9, 2022 23:58 |
how to run fluent from matlab without using aas toolbox? | artemis96 | ANSYS | 7 | May 23, 2022 12:16 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
