April 27, 2023, 07:56 |
DPM injection number tracked = 0
zhubin
Rep Power: 3 |
Hello, everyone
I am currently working on unsteady particle track with a transient flow. The nickel particles (density = 8900 kg/m3) can not be tracked, and the console shows: " Advancing DPM injections.... number tracked = 0, escpaed = 0.... " It's a 2D axisymmetric model with a minimum mesh size of 0.002m, 0.001s fixed time step. The particles are injected from the inlet, surface type, and the parameters were set as other parameters by default. So, if anyone has ever encountered this problem, please tell me the possible reasons. |
July 25, 2023, 17:18 |
erphan
Rep Power: 3 |
Hi Zhu
maybe the problem is your particles are NOT located in your domain. usually, I faced to this error while using DPM, when my particles located out of the domain. |
dpm, number tracked |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 03:34 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Controlling Number of particles in Surface Injection (DPM) | santoshroopak | FLUENT | 7 | August 3, 2013 12:17 |
