Spheres Falling in Water using Macroscopic Particle Model (MPM) in Fluent |
April 23, 2023, 19:00 |
Gerald
I am attempting to simulate a sphere settling under gravity in a viscous fluid (water for now) using the Macroscopic Particle Method (MPM) in Fluent 2023 R1. I managed to set up a sphere falling in air by watching a good video posted on the YouTube channel (just to avoid posting external links, the title is [TUTORIAL] Macroscopic particle Model di Ansys Fluent (MPM)) mentioned by the user Erasmus in the thread Macroscopic particle model (MPM) , but when I try to set up spheres falling in water with steps from another video posted on the same YouTube channel, the spheres either don't move or the behaviour is unphysical. Also, the continuity residuals are very large. The geometry I use is very similar; it is slightly simplified to be just a rectangular box without the reduction in size in the middle of the domain, but uses the same overall dimensions from the video. The mesh I am using has very similarly sized tetrahedral elements as well. I am following the steps as closely as possible, but I still cannot replicate the behaviour from the video. I should note that I had to replace the animation setup from the videos with the more current "scene" setup. Would anybody have any advice on this issue? Thanks! Last edited by gpjg; April 24, 2023 at 04:35. |
fluent, mpm, multiphase model |
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate | Kieyo | Fluent Multiphase | 0 | November 9, 2022 23:58 |
how to model many particle falling in a container | ztdep | Fluent Multiphase | 0 | November 15, 2018 21:53 |
Macroscopic particle model | sbiswas12000@yahoo.com | Main CFD Forum | 1 | October 26, 2017 03:57 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
