Calculating the flow rate across sides/curved surface area |
April 22, 2023, 18:33 |
Nasir
Rep Power: 3 |
Hi everyone,
I simulated the mixing of methane gas in water using an MRF model. Below is the description of my model. Multiphase Eulerian, viscous SST model k-omega dispersed, Implicit formulation, rotor (MRF zone), Stator(stationary zone). I could find the volume flow rate across at the top and bottom of the MRF zone(shown in image 1,3) using post-processing tools. My question is:How can I find the volume flow rate moving across the walls (marked by arrows in image 2). Else, is there a better way to quantify/calculate the volume flow rate through the upper, lower and side wards boundaries (“caps”) of the rotating domain? Thanks in advance Last edited by Nasir_Aziz; April 22, 2023 at 18:35. Reason: Font |
April 24, 2023, 11:05 |
Rep Power: 17 |
Here is one approach with just post-processing.
1. Create an isosurface of Radial Coordinate (under Mesh variable). 2. Create an isoclip of this surface from the min/max values of Y-Coordinate. 3. Report -> Surface Integral of Radial Velocity over the isoclip. Note, this will give a volumetric flow rate. |
April 25, 2023, 15:30 |
Nasir
Rep Power: 3 |
Hi NickFL,
Thank you for ur response. Will try this it seems like a better alternative . Regards Nasir |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 12:16 |
Mass Flow Rate Over a Sampled Surface | GRAUPS | OpenFOAM Post-Processing | 8 | April 21, 2021 08:11 |
cavitatingFoam: calculate the mass flow rate in a specific area | sylv20 | OpenFOAM Post-Processing | 4 | September 30, 2015 05:36 |
Mass flow rate defined by velocity function and inlet area | saml | Fluent UDF and Scheme Programming | 4 | July 17, 2015 11:08 |
mass flow rate on the Iso-clip surface & interior | Sunil Gupta | FLUENT | 0 | April 22, 2008 09:29 |
