Outlet boundary condition for pipe cut-off face |
April 22, 2023, 12:57 |
Chenxi
Rep Power: 4 |
Hi everyone,
I am simulating the inner flow field of part of water pipeline. The VOF model was appplied as the flow is open channel flow. The inlet boundary was set as mass flow inlet. I am confused about the outlet boundary condition now. Should I use pressure outlet or outflow boundary condition? If I use pressure outlet boundary, what gauge pressure should I give when the outlet boundary do not connect with atmosphere? If I use outflow boundary condition, the air phase is compressible , which Ansys User's guide don't recommed using outflow boundary for compressible phase. Can anyone give me some suggestions on my problem? Thanks in advance. |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 08:07 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
