Workbench Fluent save every DP in Legacy format |
April 20, 2023, 03:44 |
Rep Power: 6 |
I am running multiple Design Points within the Workbench with Fluent. I want each Design Point to be saved in Legacy format (in order to get access to all variables in CFD-Post, which I believe I don't get writing in CFF format, please correct me if I'm wrong). Setting the Setup in the Fluent Block within the Workbench up via: File -> Preferences -> Default Format for I/O -> Legacy .. I receive this error: "C:\Users\myname. A subdirectory or file with the name "myname\.fluentconf" already exists. The following error occurred: myname\.fluentconf." i already deleted that file and the Ansys folder in the Appdata directory... Any help on this is highly appreaciated! |
April 20, 2023, 04:56 |
Rep Power: 6 |
Update: This way (even though the error appears) I can actually save the file of that specific (current) design point in the legacy format.
When I update other Design Points they are then unfortunately saved in CFF format again. As a restult in CFD-Post I can't access variables such as the mach number etc... |
design point, fluent, legacy, workbench |
Sutile and Tricky : Drive Fluent UDF parameters directly from workbench | amscosta | Fluent UDF and Scheme Programming | 4 | July 21, 2020 16:50 |
save to variable filename inside loop | FrankR | Fluent UDF and Scheme Programming | 5 | January 30, 2019 11:16 |
[ANSYS Meshing] polyhedral mesh which is generated directly in Workbench Poly Meshing for Fluent | teguhtf | ANSYS Meshing & Geometry | 0 | January 24, 2019 22:04 |
implementing UDF for fluent in workbench for running multiple simulations | faizan_habib7 | Fluent UDF and Scheme Programming | 0 | March 18, 2016 22:29 |
FLUENT WORKBENCH vs FLUENT | rcerdeira | FLUENT | 0 | March 17, 2010 05:05 |
