Seokmin
Rep Power: 0 ![]() |
I used fluent 2022 R2.
But now I use a license which is donated to university (2021 R1). So I can't use mesh file from 2022 R2. I converted CAD file extension from .scdoc file to .stp (STEP) file. I open .stp file in 2021 R1 and save it as .scdoc file (I did Namedselection again.) After that, I tried to make a mesh. But I have three problems. (even though I could make a mesh well in 2022 R2) 1.When I made a surface mesh, warning messages(black color) appears in the conosol window (Warning: Region is named after face zone label "outer-shield" with maximum surface area out of multiple face zone labels (lower-ring lower-shield lower-dome)) I think that it's a just message, but i'm not sure. 2.When I made a surface mesh, warning messages(yellow color) appears in the conosol window ---- Warning--- Due to the size of the model, faces of bodies were not automatically separated for capping and/or size assignment ---- Warning--- To separate out zones, Edit the task and in Advanced Options, set 'Invoke Zone Separation by Angle?' to 'yes 3.When I make a capping, it takes too long time. (it takes just a minute in 2022 R2, but it takes an hour in 2021 R1) Does anyone know how to fix these? My CAD file has complicated shapes. Because it's a CVD Chamber. There are many parts such as susceptor, dome, wafer, lamps, reflector, inlet pipe, outlet pipe, etc. And the quantity of lamps is high (about 100 lamps) Is there a limit of # of namedselection or shapes in CAD? |
ansys, fluent, mesh |
Fluent Meshing poly-hexcore meshes for CFX | siw | CFX | 2 | November 18, 2021 09:49 |
[ANSYS Meshing] Fluent Face Meshing Problem with two trimmed ellipse | Silverwing | ANSYS Meshing & Geometry | 0 | December 6, 2018 23:19 |
facing problem in dynamic meshing motion preview in fluent | hitesh0401 | Fluent UDF and Scheme Programming | 6 | May 8, 2014 15:59 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
[ICEM] Meshing problem from ICEM CFD to Fluent | cfdonlinederafa | ANSYS Meshing & Geometry | 2 | September 21, 2010 16:16 |
