DingHui Wang
Rep Power: 0 ![]() |
I would like to seek advice on simulations involving chemical reactions using catalyst in FLUENT.
How do I decide the value of third-body efficiency in Fluent when setting up the model? Can that be calibrated those values using experimental data? The main difficulties/confusions to me is that I am simulating a bimetallic catalyst, with different metallic compositions. In the literature, the same set of reactions seemed to be used to compute the results. When I tried to setup the simulation by duplicating the reactions, it seems that Fluent simply calculation the same reaction twice. Can someone advice on what would be a better way to set up the chemical reactions kinetics in Fluent in this case? |
Convergence Problem - Transient Simulation | gemxx | Main CFD Forum | 0 | July 15, 2018 09:36 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 05:28 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 02:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
Simulation nox | cui | FLUENT | 0 | May 9, 2006 04:41 |
