Some questions about adiabatic wall
Old   April 12, 2023, 07:39
Default Some questions about adiabatic wall
Y. C. Peng
*Gasp* is on a distinguished road
Hi everyone,
It's been a year since I started using FLUENT, but I still have several questions about the setting of boundary condition.
1st:
Is it correct I set both "heat flux" and "heat transfer coefficient" to 0 if I wanted to keep a wall in adiabatic condition?
2nd:
If I apply a UDF with thermal conductivity(it will change over temperature) to the material of the wall, will it affect the adiabatic condition?
3rd:
According to the question above, If both the UDF and the boundary conditions have an impact, which one has a greater influence during the calculation? Will they both affect the solution or is one more dominant than the other?
Does anyone have any idea?
Thanks for advising.
*Gasp* is offline   Reply With Quote
Old   April 12, 2023, 08:44
NickFL is on a distinguished road
Are you simulating both the fluid side and the solid side? Or just the fluid side?
1. If you are modeling the fluid side only, you do not need to do anything to have an adiabatic condition. If you are modeling the wall, the heat transfer coefficient will be computed and not an input at the interface of the fluid/solid.
2. The thermal conductivity can be inputted without using a UDF in a number of ways. You can use the piecewise-linear, polynomial or other options. Is there a need to go-to the UDF?
3. The boundary conditions have precedence over the computed solution at the boundary. The thermal conductivity is a material property and therefore will influence your solution inside the domain.
NickFL is offline   Reply With Quote
heat flux at wall vs adiabatic vs constant temperature Shamoon Jamshed FLUENT 2 March 18, 2021 09:07
questions on wall film simulation 2 learner1111 CONVERGE 1 June 5, 2017 14:00
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Radiation interface hinca CFX 15 January 26, 2014 18:11
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
