fluent crashes when using "()" in TUI command
Old   April 12, 2023, 07:08
Default fluent crashes when using "()" in TUI command
Jad Diab
jdiab is on a distinguished road
I am trying to change the boundary condition using a TUI command (to be used in schemes later on), but fluent keeps crashing when I using the "()" brackets to end the list when choosing the zones to specify the boundary condition on, did anyone face this problem before?
the TUI command: define/boundary-conditions/set/wall/ce2 ()/uds/no/500
Thank you in advance
jdiab is offline   Reply With Quote
Old   April 12, 2023, 08:13
NickFL is on a distinguished road
Try a comma instead of the (). You have ce2 as your wall as the first zone that is defined. Adding a , will then say there is no more zones you want to select.
NickFL is offline   Reply With Quote
ansys, fluent, tui
Two phase flow in porous medium Milaad OpenFOAM 7 July 1, 2024 06:08
fluent text command doesnt show all options! m2montazari FLUENT 3 March 13, 2017 00:56
Fluent Tui Command for transient MachZero FLUENT 5 January 17, 2017 14:57
Fluent TUI command, How to do it? Ash Kot FLUENT 2 October 17, 2016 14:42
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 12:37
