How do you change the colour map on a sweep surface? |
April 10, 2023, 12:45 |
Rep Power: 5 |
I can't for the life of me figure out how to do this. I want to do a total pressure sweep, and I like having the 'max' value colour set to white so it's easy to visualise. On static contours there is a colour map button, but not so using the sweep surface feature in 2022 R1. Any ideas?
Surface sensitivity map in optimization | Drean | SU2 | 1 | March 10, 2023 03:50 |
Can particles change the surface of fluid/surface | Xiao_Zheng | FLOW-3D | 0 | July 2, 2022 22:16 |
Error in gmshToFoam on ESI v2106 | siefer92 | OpenFOAM Programming & Development | 4 | July 17, 2021 06:11 |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 12:12 |
How to write UDF for UDF to change heat transfer coefficient along the surface of the | krishna.n | Fluent UDF and Scheme Programming | 0 | March 8, 2017 10:58 |
