Wrong side boundary condition with layering method. |
April 8, 2023, 14:51 |
Liang Quan
I am simulating a 2d compressed cylinder using layerng method with the bottom moving up and down. I want to use the top layering method (constant mesh near the bottom, layering near the top). I set the bottom and fluid to be rigid body in motion, and the top is stationary. The air near the side wall has the same speed as the bottom. But it should be zero because the side wall is stationary.
(see and ) Later, I found that there would be two cell zone after the mesh was imported into fluent, one named fluid and the other with interior prefix, the former with boundary and the latter without. I changed the "fluid" in the dynamic mesh zone to "interior-fluid", and the result was correct, with 0 velocity near the side. (see and ) Later, I want to simulate the 3d situation, but after the mesh is imported into fluent, there is only "fluid" but not interial-fluid on the "mesh display" window, and the simulation result shows that there is speed around the side. May I ask how to solve this problem? If anyone has any suggestions, I'd be most grateful. |
layering |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Question about different kinds of Boundaries and Boundary Conditions | granzer | Main CFD Forum | 17 | April 12, 2022 17:27 |
Cyclic boundary condition in foam-extend 4.0 | rellumeister | OpenFOAM Pre-Processing | 2 | March 3, 2020 08:03 |
Constant mass flow rate boundary condition | sahm | OpenFOAM | 0 | June 20, 2018 22:45 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
