Residual fluctuations and inconsistent lift and drag coefficients in Fluent |
April 8, 2023, 12:09 |
Hello all,
I am conducting an analysis in Fluent software, focusing on lift and drag coefficient at different angle of attacks. However, I have noticed that the residual values display fluctuating characteristics and the lift and drag coefficients do not converge to a certain value at 6 and 10 degrees. For 4 degrees, solution converges and residuals do not fluctuate, since flow does not separate. I have attached an image showing the velocity vectors at 4, 6, and 10 degrees and residuals at 6 degrees for reference. To obtain a more accurate analysis, I am seeking guidance on how to approach this issue. I have tried reducing the velocity at 6 degrees to decrease the flow separation and subsequently decrease the residual values, resulting in a slight convergence of the lift and drag coefficients. However, my analysis involves a Mach number around 0.8, and I am currently using the kw-SST method. I would like to have a converged solution even if there is a flow separation. I would greatly appreciate any suggestions or solutions that you may have regarding this problem. Thank you in advance for your assistance. Best regards |
April 10, 2023, 18:27 |
Maria dl valle
Rep Power: 3 |
I'm not expert... but did yoy control the Y+? is very important with k-w.
July 2, 2024, 22:24 |
Qin Yajie
Rep Power: 2 |
Maybe you can try a transient simulation to study the separation manner.
cfd aerospace, convergence, separation |
