Capillary Rise in Porous Media Modelling
Old   April 5, 2023, 11:45
Smile Capillary Rise in Porous Media Modelling
KN
kof099 is on a distinguished road
I am trying to model capillary rise in a 2D model of a 1mm tube in a tank using Fluent.
I'm using Eulerian-VOF multiphase modelling for 2 phases - water and air. Wall adhesion is activated and I've applied a contact angle of 30deg to both the tube and tank walls, surface tension of 0.072 N/m and set the flow as laminar.
All other values have been left as the default. The tube and tank have been patched with water.
The problem I'm having is that after the tube reaches it max. height of 12.5mm at t=0.1s, it begins to decrease before levelling off at around 9.55 mm at t=2.5s.
Have I made an error somewhere that results in the water level not staying constant at its max. height?
Thank you.
kof099 is offline   Reply With Quote
capillary rise, multiphase flow
Modelling grid as porous media iljar CFX 1 April 2, 2019 09:51
2D Porous Media Modelling alfie FLUENT 0 July 25, 2016 08:04
Porous media modelling dreamlifter747 Main CFD Forum 1 October 3, 2013 09:22
Modelling porous media Rina Main CFD Forum 0 April 10, 2002 11:01
Modelling porous media adjacent to viscous flow Rina Lum Main CFD Forum 1 March 25, 2002 17:55
