UDS difiiusity
Old   April 4, 2023, 19:50
Default UDS difiiusity
Peyman
p.norouzi.gv is on a distinguished road
Hi all, In the ANSYS FLUENT, the units for diffusivity are kg/(ms) while the conventional units for diffusivity (m^2/s). so it means that Fluent is solving *
I have to solve this equation dC/dt= D div(div C)+ s . If*I multiply all the parameters with rho the current equation will be:
d(rho*C)/dt= D div(div roh*C )+ s*rho. I was wondering if it is the correct way to change my equation to the fluent format.
thanks in advance for your help.
p.norouzi.gv is offline   Reply With Quote
udf code, uds
Dye mixing inside a tank : UDS or Species Transport or DPM ? Axel1 FLUENT 1 March 17, 2024 01:45
Change UDS Inlet Typ with UDF possible? schwaral Fluent UDF and Scheme Programming 8 September 17, 2020 09:47
Set UDS on wall... fivos Fluent UDF and Scheme Programming 2 July 25, 2014 06:57
Calculate UDS flux through the wall ananth_01 FLUENT 0 August 5, 2013 08:33
Doubts UDS Flux, UDS Unsteady for VOF model kel85uk FLUENT 0 March 17, 2010 09:53
