Outflow of water at high pressure and temperature through a gap in a two-phase state
Old   April 4, 2023, 13:28
Smile Outflow of water at high pressure and temperature through a gap in a two-phase state
Max Lang
New_CFD_user is on a distinguished road
Good day,
I apologize if I make any mistakes, but I am new here and have never worked with a forum before. This is also my first time using Ansys Fluent
I want to simulate a "crack" in a metal disc filled with water at, for example, 20 MPa and 185°C. I have created the geometry and used "pressure inlet" and "pressure outlet" as boundary conditions. For the model, I am using k-omega and VoF, and I have entered the phase transition of water with a UDF, i already found.
For both water and steam, I have left all settings at the default values. I know that these will need to be changed as water has different viscosity and density with changes in temperature and pressure.
In the single-phase region, everything worked fine, and now I want to simulate it as a two-phase system.
Unfortunately, my results always diverge, and I don't know what I need to change.
Perhaps someone has an idea on how I can better implement the simulation to have a two-phase outflow.
Thanks in advance for the help."
New_CFD_user is offline   Reply With Quote
two-phase flow, water + vapor
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Averaging over iterations for steady-state simulation CFD student Fluent UDF and Scheme Programming 8 September 22, 2022 04:39
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
error message cuteapathy CFX 14 March 20, 2012 07:45
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
