April 2, 2023, 14:24 |
Nusselt number and friction factor
inj3ct0r
I have a pipe with fluid inside and heat flux applied from the outside, I want to get the Nusselt and friction factor values for Dittus-Boelter equation validation, is it calculated manually or we get the value from fluent? as I've seen research articles doing validation with the equations and it is in the range, while mine is not. Thank you |
April 3, 2023, 03:32 |
Rep Power: 17 |
You will have to do a bit of post-processing for the values you need. The pressure drop is going to be the pressure at the inlet minus the pressure at the outlet. You may have set the pressure at the outlet to be 0 [Pa], so in that case the subtraction is simple enough that I can do it in my head. For the heat transfer (Nu) part you could integrate the local heat flux over the entire surface to get the complete heat flux that is typically used when computing the average Nu. Notice the heat flux will be highest near the inlet (when the temperature difference is the greatest) and lower as we move downstream.
Also depending on how long your pipe is and what you have for your inlet velocity boundary condition, that could contribute to a source of error. A more appropriate fully developed inlet profile could be parabolic or a 1/n profile depending on the Reynolds number. |
friction factor, nusselt |
Nusselt and friction factor validation in turbulent flow | me.po | FLUENT | 7 | July 24, 2023 03:16 |
Friction factor inside a pipe with low very low Reynolds number locally | user9 | Main CFD Forum | 2 | August 22, 2022 12:54 |
friction factor vs Reynolds number | esha | Main CFD Forum | 3 | December 4, 2018 10:01 |
calculate friction factor & nusselt number | soheil1991 | FLUENT | 3 | March 11, 2017 09:30 |
Calculation of Friction Factor & Nusselt Number | mypassion59 | FLUENT | 1 | July 9, 2014 14:31 |
