April 1, 2023, 12:34 |
Streamlines stopping at domain boundary.
Robbie
Rep Power: 3 |
Hi all,
I've modelled a centrifugal pump using the mrf approach, and would like to see streamlines throughout. As you can see from the image attached, the streamlines are stopping at the boundary for the mrf domain. Is there a way to make them pass through? I've tried fiddling with the streamline settings to no avail. The domains are set to "all domains". I've tried setting up planes further down from the inlet and they still stop at the domain boundary. Any advice? Thanks in advance. |
April 1, 2023, 14:20 |
Lorenzo Galieti
Rep Power: 12 |
When you plot the streamlines, there was an option to govern how long the streamlines should be, if i recall well. Maybe you just need to tweak that
April 2, 2023, 07:25 |
Robbie
Rep Power: 3 |
Unfortunately that setting seems to have no effect. Interestingly, when the plane the streamlines start from is within the mrf body, the streamlines are able to leave the mrf domain and go to the exit. I don't quite understand why they would decide to simply stop at the entrance to the mrf domain.
April 3, 2023, 04:13 |
Rep Power: 17 |
What rotating interface model are you using? As these streamlines are so straight, can you just start the streamlines from the interface?
Ich war nie begeistert von der Stromlinienfunktion in Fluent. Oft musste ich zu CFD Post wechseln, um die gewünschten Ergebnisse zu erhalten. |
fluent, streamlines break |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Closed Domain Buoyancy Flow Problem | Madhatter92 | CFX | 6 | June 20, 2016 22:05 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 22:16 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
