Dye mixing inside a tank : UDS or Species Transport or DPM ? |
Rep Power: 0 ![]() |
Dear all,
I am studying the mixing properties inside a tank both experimentally and numerically. I already realized a steady 3D simulation of the water flow inside the tank. Simulation and experiments are in good agreement. I also realized experimentally a continuous injection of dye and would like to reproduce this using simulation BUT by using transient solver to get time-dependant informations concerning mixing. I already tried to use UDS for the dye which have same physical properties as water. As a result, the UDS seems to only diffuse from the inlet and is not convected by the flow. See Attachements at 1s, 100s and 200s. Here is my procedure step-by-step: 1) I defined a UDS with Flux Function on "mass flow rate" 2) I switched to "Transient" solver 3) In BC, I enter a Specified Value of UDS = 1 at the Inlet and a 0 Flux value on other boundaries. 4) In Controls panel, I unchecked Flow and Turbulence equations to only solve transport equations of my UDS and to keep the flow solution obtained from steady solution. 5) I did NOT initialize and i ran calculations with time-step size = 0.1s. So my questions are : - Is it possible to use a steady flow solution and then use this solution to solve time-dependant UDS transport ? I feel like it should be douable but i am probably missing something. - I think that other methods as Species transport or DPM are also usable in my case ? What would you recommend between those 3 ? (I am afraid that Species Transport and DPM migth require high computation time) Thank you so much in advance. |
Fixed Bed Gasifier, Species Transport Problem | therandomestname | FLUENT | 12 | January 4, 2019 07:08 |
Mixing tank, MF-VOF and Species Transport - Divergence Error | soheil_r7 | Fluent Multiphase | 0 | September 11, 2018 05:29 |
Species transport and DPM in cooling tower | noraishah@nm.gov.my | FLUENT | 7 | July 11, 2017 06:00 |
Modelling species transport and implementing reaction rates | res | FLUENT | 0 | May 11, 2017 10:29 |
species transport and DPM | suailek | FLUENT | 0 | April 25, 2005 21:48 |
