March 24, 2023, 09:20 |
Population Balance Model
AgisFitrony
I am currently working on simulating the breakup of bubbles through a venturi pipe using the PBM method. The simulation involves a primary phase of liquid and a secondary phase of gas (bubbles), with liquid velocity of 4.16 m/s and gas velocity of 0.16 m/s. However, when I tried to validate my simulation data with experimental data, the results did not match my expectations. Please refer to the following link for an image of my validation results: I have used the Luo model for both the breakup and aggregation kernels. To validate my simulation data, I have extracted the experimental data in the form of a mean of 0.36 and a standard deviation of 0.12. However, I am uncertain if there is something that I have missed in my validation process. Furthermore, I am also interested to know how to convert a number density function (NDF) into a probability density function (PDF). As far as I understand, to obtain a PDF from an NDF, I simply need to divide the number density in a particular bin by the total number density. However, I am still unsure if this approach is correct. Can you please provide some guidance on this matter? Thank you. Sincerely, Agis Last edited by Agisfit; March 24, 2023 at 09:23. Reason: attach image |
Coupling RPI wall boiling model with population balance model in Fluent | softice2006 | Fluent Multiphase | 1 | April 19, 2023 03:09 |
Population Balance Model in Fluent - Surface area of changes due to diffusion of part | adib_mohammad | FLUENT | 1 | November 14, 2021 20:21 |
Reaction Species transport and Population Balance | abgoel363 | Fluent Multiphase | 0 | January 20, 2020 08:08 |
Population balance model for twofluid model | pierre | OpenFOAM Running, Solving & CFD | 9 | March 19, 2016 14:46 |
UDF for the population balance model | Hossam | Fluent UDF and Scheme Programming | 0 | March 27, 2009 03:46 |
