Related to static pressure contour in ANSYS Fluent
Old   March 24, 2023, 08:53
Default Related to static pressure contour in ANSYS Fluent
msd
Heer
msd is on a distinguished road
Dear All,
I am working in ANSYS Fluent with some gravity-based simulations. But as I switch on gravity, the results don't reflect any change when compared with simulations where gravity was not included. Related to this, I was confused that how is static pressure defined in Fluent. Can please anyone help me with this? I am also not clear why my static and total pressure contours are having the same value.
Thanks in advance!
msd is offline   Reply With Quote
Old   March 27, 2023, 04:46
NickFL is on a distinguished road
This is a common question. I used to have a slide from ANSYS with a good description, maybe someone here has it. Note there are three pressures in Fluent: static, total and absolute.
static - this is the pressure we typically set in the solver. It is like a gage pressure in that it is measured off a given reference pressure. This is what the solver uses when computing the pressure.
total - this is a combination of the static and dynamic pressure (1/2*\rho*v²) terms.
absolute - this is static and the reference pressure which is set in the Reference Values panel.
If you want to visualize the hydrostatic pressure, I would recommend creating either a Named Expression or Custom Field Function. The solver does not need this hydrostatic pressure for the solution, so it does not automatically output it.
NickFL is offline   Reply With Quote
Old   March 27, 2023, 04:53
msd
Heer
Thank you, Nick for your reply!
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Kieyo Fluent Multiphase 0 November 10, 2022 00:58
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 07:33
Recursive output of Foam::word in gdb print command chengdi OpenFOAM Programming & Development 1 July 19, 2017 21:19
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
