Effect of the MHD model on DPM particles
Old   March 23, 2023, 09:50
Default Effect of the MHD model on DPM particles
cdsomer is on a distinguished road
I am trying to quantify the effect of magnetic fields on discrete particles under fluid flow in a 2D bifurcation using the DPM and MHD model.
The magnetic field is oriented in a way such that I expect more particles to pass through one of the outlets.
I have no problem importing my magnetic field and visualising it and the induced B field.
However, when it comes to the DPM, the magnetic field does not influence the particle trajectories.
How can I fix this?
My current settings are:
for MHD, I make use of magnetic induction. First I intialize both MHD and DPM then I import my B field and run the simulations.
for DPM: I use interaction with the continuous phase, steady particle tracking and the physical models: Pressure Gradient force, Saffman Lift force and virtual mass force.
cdsomer is offline   Reply With Quote
dpm fluent, mhd in fluent
set up DPM model in fluent ebtedaei FLUENT 0 February 20, 2018 11:39
UDF charge density in mhd model dpm G-NO Fluent UDF and Scheme Programming 0 April 25, 2017 21:42
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. Ari Fluent UDF and Scheme Programming 4 May 31, 2016 09:51
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 12:58
question of DPM model Cindy Jones FLUENT 8 November 18, 2002 22:58
