Specifies the flow rate of the fluid domain in the room |
March 12, 2023, 23:40 |
Jie-Ying Zhan
Rep Power: 3 |
Hi everyone, I'm simulating a data center room, and I got a problem, to simplify my problem, I'll illustrate it with attached pictures. The first picture shows the design of the whole room. The blue boxes are the servers, and the red surface has been set as the Radiator as the heat source.
My question is how do I specify the mass flow rate of each Server? The second picture shows my goal. If there is any part of my expression that is not clear enough, please let me know, and I will explain it. |
March 13, 2023, 12:19 |
Lorenzo Galieti
Rep Power: 12 |
So you want to specify the mass flow exiting from each outlet? There is mass flow outlet BC for that. But then at inlet you specify pressure, not mass flow. Otherwise your problem is ill-posed
March 14, 2023, 23:05 |
#3 | |
Jie-Ying Zhan
Rep Power: 3 |
I tried to change the inlet of the room to pressure and set the mass flow outlet on each outlet, but my calculation will diverge. Is there any other way? |
March 15, 2023, 11:11 |
Lorenzo Galieti
Rep Power: 12 |
I find very weird that it doesn't converge. I must be honest, I think that you made a mistake somewhere.
March 16, 2023, 02:52 |
Rep Power: 17 |
In your first image you are not showing an inlet for the servers, only an outlet (in red). Both servers need to have an inlet to account for the fluid that is coming out. The inlet & outlet into the server should be the same amount with only a temperature difference. This is probably accounting for your divergence when you have more or less entering than physics allows.
A more advanced model would be to couple the flow rate through the server by knowing the resistance. Then you could treat this pair with a fan boundary condition. |
March 16, 2023, 04:56 |
#6 | |
Jie-Ying Zhan
Rep Power: 3 |
The reason I don't have inlets on the servers (red faces) is that I have to set there faces as the heat source so I can't add inlet BCs on there faces. I have tried fan's BC before, but I think that is not what I need. |
March 16, 2023, 05:35 |
Rep Power: 17 |
OK, that makes some sense. That means your hand drawing above showing the air going through the servers is not correct. What you are modeling is natural convection from a vertical wall on each server. This might not be the most accurate way to model it, because the servers will likely have air flowing through them. But it might produce a good first approximation.
Two mass-flow outlets and a pressure inlet should converge quite well. Does it work if you switch them (both outlets as pressure and inlet a mass flow rate)? What equation(s) is(are) not converging? Does it converge with just flow (i.e. energy off)? What properties are you using for air (boussinesq, ideal gas)? There are many things that could be the reason. |
March 20, 2023, 05:55 |
#8 | |
Jie-Ying Zhan
Rep Power: 3 |
The attached file is the model I actually want to simulate and the results I want to get. Is there any other way to do it? |
March 20, 2023, 06:00 |
#9 |
Lorenzo Galieti
Rep Power: 12 |
as I said, you made a distraction mistake somewhere, or perhaps the mesh is really bad. Incompressible flow with a pressure and massflow BC has to converge, no question about it.
Without you showing us mesh and settings one by one, it is impossible to understand what is going on. I have no crystal ball. |
fluid domain, mass flow rate, specified value |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 18:19 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 11:20 |
two fluid, volumetric/mass flow rate at different volume fractions | Veronique Pe | CFX | 2 | November 26, 2014 06:30 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
