combustion not initiating
Old   March 11, 2023, 01:15
Default combustion not initiating
Puru khatiwada
Puru1995 is on a distinguished road
I am running combustion simulation in a domain using rice husk as a fuel. I tried using both nonpremix and species transport model. But in both cases the fuel seems to be burning in the inlet path only without entering the main furnace domain. The mass fraction of all components that is supposed to be in the domain demonstrating the reaction isnt there. The whole domain either shows nil concentration of compounds such as CO2 and water either the concentration is same throughout the vessel. The only variation can be seen in the small duct from where the fuel enters and that is where the reaction ends. What may be the possible causes of that?
Puru1995 is offline   Reply With Quote
Old   March 11, 2023, 08:13
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
What is your turbulence/chemistry interaction model? Please post a screenshot of your species transport panel
alainislas is offline   Reply With Quote
Old   March 11, 2023, 09:56
Default screenshots
Puru khatiwada
https://drive.google.com/drive/folde...-c?usp=sharing
The turbulence model i am using is k-epsilon standard model. Please provide me the feedback. Thank you for your time.
Old   March 11, 2023, 10:07
alainislas's Avatar
Alain Islas
Please next time, attache the images directly here in the forum.
I see your TCI is EDM, this is a mixing limited TCI model, where reaction rates are assumed as inifinitely fast but controlled by turbulent mixing only. In order to avoid flame ignition befoer a flame holder (or at an inlet for example), please use the EDM/FR model. FR acts a kinetic switch, preventing reactions to take place in zones where the FR RR < EDM RR. Please go through the theory manual https://www.afs.enea.it/project/nept...th/node129.htm
Old   March 11, 2023, 10:27
Default Thanks
Puru khatiwada
Thank you for the feedback
Old   March 11, 2023, 10:44
Default incomplete combustion
Puru khatiwada
Please provide me a suggestion on this.
Using finite rate model improved the simulation result and the combustion seems to happen in the main cylinder.
How to make sure that the combustion is complete since there is no option to view carbon monoxide concentration in the results. The concentration of fuel is nil while carbon dioxide is very low as well.
Old   March 11, 2023, 10:51
alainislas's Avatar
Alain Islas
What do you mean by combustion is complete? To provide suggestions, I need to know more about your case.
1. Is this a transient simulation?
2. How are you injecting the fuel?
3. What is your equivalence ratio?
4. How are you igniting the mixture?
5. Did you add the CO to your mixture? Show your species panel
6. You can track O2 mass fraction at the outlet and check whether its consumed or not.
Please elaborate
Old   March 11, 2023, 11:20
Default Details
Puru khatiwada
> I mean that the concentration of carbon dioxide is very low in the order of 10^-11.
>No
>The air enters tangentially through a rectangular inlet and the fuel drops on the air stream from the top in perpendicular direction such that the air carries it.
>Around 0.9
>I have one of the walls that holds the nozzle maintained at 500K.
>No. I used the coal calculator and the reactants and products are as shown in the image earlier.
>The oxygen is at same concentration throughout the domain.
Old   March 11, 2023, 13:19
alainislas's Avatar
Alain Islas
Again, please re-attach your images directly here in the thread and do not use external links. This facilitates many users and I to jump into the conversation, avoid going to untrusted sites, and provide better assistance.
1. From what I saw (I will not open again the link), you only had 1 volumetric reaction, but before that. Are you really devoatilizing the 'vol' species in the particle? Please take a look at some contours.
2. Are you really injecting the DPM? What is your DPM mass flow rate? Take some screenshots of the DPM trajectories and add them here.
3. 500 K for ignition is too low, what is your devolatilization temperature? Besides that, do you have any other DPM law enabled? If you have moisture in the DPM, what about the evaporation? This will of course consume enthalpy and decrease your temperature.
4. The coal calculator has a template that directly adds the participant species in the volumetric reaction into the mixture. Did you add any solid species too?
4. Any judgment should be done after reaching a steady-state condition-
Old   March 11, 2023, 23:17
Default Response
Puru khatiwada
From what I saw (I will not open again the link), you only had 1 volumetric reaction, but before that. Are you really devolatilizing the 'vol' species in the particle? Please take a look at some contours.
I am including some of the contours. They are not as better as they were before changing the injection settings
it seems like i hadnt customized the injection settings. I have included the latest settings here
i increased the temperature to 1000K
I dont think so
Old   March 11, 2023, 23:45
Default Response
  #11
Puru khatiwada
Attachment 93703
Attachment 93706
Attachment 93707
Attachment 93708
I dont think so
Old   March 12, 2023, 12:08
Puru khatiwada
the injection
no combustion reaction
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 05:10
Partially Premixed Combustion - Direct Fired Boiler oknus FLUENT 0 April 10, 2012 11:52
hydrocarbon gases + Boron particle combustion nileshjrane OpenFOAM 1 December 13, 2010 07:20
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 19:40
Need Similar Combustion Tutorial as my model Arnab Siemens 0 May 24, 2005 19:23
