How do I set the Absorption Coefficient, Scattering Coefficient, Refractive Index |
March 8, 2023, 04:54 |
Williams
Rep Power: 11 |
Dear everyone!
I want to simulate a hollow cylinder internal and external flow field and temperature field based on fluent, the temperature of the top surface of the cylinder is 500℃, the air temperature outside the cylinder is 20℃, the diameter of the cylinder is 500mm, the height is 500mm, the bottom of the cylinder is a quartz glass, the thickness is 25mm. the simulation process should consider the natural convection and radiation heat transfer. pic1.jpg In the modeling process, quartz glass is a semi-transparent medium, so I use DO radiative heat transfer model, I know that the transmittance of quartz glass plate is 0.9679, the reflectance is 0.0296 and the absorbance is 0.0025. How do I set the Absorption Coefficient, Scattering Coefficient, Refractive Index in the material properties of quartz glass? and Diffuse Fraction in the quartz glass boundary conditions? pic2.png pic3.png Thank you in advance, your sincerely gearman! |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
absorption and scattering coefficient of air for DO model | charlie.dho | FLUENT | 4 | July 5, 2020 08:35 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 14:32 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
