How to set Outlet Guage Pressure in ANSYS Fluent for Centrifugal Pump? |
Pratik Chalke
Rep Power: 3 ![]() |
I am doing analysis of centrifugal Pump which is supposed to develop suction head (Hs) = 7mtrs and Delivery Head (Hd) = 35mtrs with Mass Flow Rate (m) = 32.6kg/s.
1. I am giving Boundary conditions in Fluent as Inlet mass flow rate and Outlet Pressure. Now if I convert Hd to Outlet Pressure using Head = Pressure/(Density * g) then should i directly enter this pressure as gauge pressure in the outlet pressure BC? Since default Operating Pressure in Fluent is set as 10325 Pa. If not what am I doing wrong? 2. If I have to set Inlet Pressure BC do I need to Set it Negative, since the pump will be creating suction pressure? |
boundary conditions, fluent, pressure |
Fluent BC on Vacuum Pressure Outlet | ronaldgan | FLUENT | 0 | October 1, 2019 00:19 |
Question about Pressure Field in ANSYS Fluent | fjmaxfjmax | FLUENT | 6 | March 7, 2016 14:42 |
pump outlet pressure higher than inlet pressure | jstan3 | FLUENT | 14 | February 13, 2014 23:44 |
Question Concerning Pressure Value (Pressure outlet) and Reference Pressure (Physics) | andy_flow | STAR-CCM+ | 1 | July 9, 2013 08:44 |
UDF in Fluent to Match Mass Flow at Pressure Outlet | Jonas Larsson | Main CFD Forum | 1 | April 29, 1999 10:44 |
