How to generate 3D overset mesh of cylinder in a body of fluid
Old   March 5, 2023, 08:57
Default How to generate 3D overset mesh of cylinder in a body of fluid
Briant
briantbx13 is on a distinguished road
Hi there, I am trying to generate an overset mesh of a finite cylinder in a body of fluid. I am not sure on how to create the named selections for the cylinder and while figuring that out, when I tried to create the overset interface in FLUENT, after initialisation, it says that there are orphan cells present. Please let me know if more information is needed, thank you!
briantbx13 is offline   Reply With Quote
Old   March 6, 2023, 11:46
Alan
PacMan is on a distinguished road
I tried overset mesh just once; I'm no expert...
There are donor-receptor cells in the overlap region, where the cells are of similar size (essential). Fluent assigns the "orphan" flag to a cell generally if there are insufficient cells in the overlap region between two boundaries (the manual states at least 4 cells are needed between two wall boundaries of two different meshes), and a receptor can't find a valid donor. See Fluent User Manual (2022R1) section 6.6.4.2
You can check where the orphan cells are situated using contour plot, select overset and then type. I don't remember which scalar is assigned to orphan cells, but you can find it out in the documentation.
Hope it helps!
PacMan is offline   Reply With Quote
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
How to generate 3D fluid mesh around a ship lzhaok6 Mesh Generation & Pre-Processing 0 February 16, 2018 17:50
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
