Calculation of parameters at the nozzle outlet |
March 5, 2023, 02:55 |
Nikita
Hello, I consider the three-dimensional outflow of the jet from the nozzle into the flooded space. I want to see the flow parameters at the nozzle outlet. I tried to make the area in the form of a cylinder using the Adapt function, and then used Separate to calculate the volume integral through the area. I noticed that the result will change depending on the number of cells. Therefore, please tell me, is it possible to calculate the parameters at the nozzle outlet more accurately? I tried to create a surface, but I did not find where you can select only the part of it that is cut off by the contour of the nozzle.
fluent |
Pump power for hoses feeding to nozzles | Rob Wilk | Main CFD Forum | 0 | February 24, 2021 10:37 |
Convergent-Divergent Nozzle with MATLAB | Obad | Main CFD Forum | 8 | June 2, 2020 15:10 |
Strange Results at Tank Outlet with InterFoam | mgdenno | OpenFOAM | 18 | November 29, 2019 00:05 |
Average flow parameters at nozzle exit | mandour78 | FLUENT | 0 | September 24, 2014 14:17 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
