Supercritical Fluid analysis in ansys fluent
Old   March 4, 2023, 08:46
Default Supercritical Fluid analysis in ansys fluent
Abhishek Kandwal
AKandwal is on a distinguished road
I am trying to do heat transfer analysis for Supercritical fluid flow. But currently I am not able tp figure out how to define fluid property for Supercritical fluid after selecting water from fluent database.
Please help in this regard since material for Supercritical water analysis in Fluent is very rare.
AKandwal is offline   Reply With Quote
Old   March 4, 2023, 13:20
Lorenzo Galieti
LoGaL is on a distinguished road
You do not impose a fluid to be supercritical, it is simply an outocome of the pressure and temperature at which it is. The equation of state you use ( the rule you select under " density") has to be capable of correctly predicting the supercritical behaviour.
So in the specific, you select water as material and then choose a "density rule" i.e. an equation of state which is appropriate for the regime.
LoGaL is offline   Reply With Quote
Old   March 4, 2023, 13:28
Abhishek Kandwal
So my doubt is that very point that what is that density rule and how to find it?
Old   March 4, 2023, 15:47
Lorenzo Galieti
some nice literature research will help you. It may also help give you an idea of what you are trying to model. I would start reading the fluent manual in the "real gas models" section.
Old   March 5, 2023, 00:39
Abhishek Kandwal
What should be operating pressure for supercritical water?
I have attached the screenshot where it is required
Old   March 5, 2023, 01:17
Abhishek Kandwal
WARNING: Invalid cp (-7.155988e+45 J/kgK) for water-liquid at temperature 0.000002 K
Can someone explain the cause of the above warning. I am unable to initialise my solution due to this.
Also earlier to this I was getting
Warning: For compressible (ideal and real) gas models with buoyancy,
it is recommended that you use a specified operating density value of zero:
After which I set operating pressure as 0.
What to do with these two warnings?
Old   March 5, 2023, 13:54
Lucky
Fluent has calculated a negative value for Cp at a temperature of 0.000002 K. This could mean that the equation of state you use is not good for this temperature if you truly meant to initialize your simulation with a very low temperature. But more than likely your initial temperature is just too low. Water isn't supercritical at the micro Kelvin temperatures so I'm guessing mistakes have been made.
Certain buoyancy models require the operating pressure to be zero. Just listen to Fluent. If you want to learn more about it, you can dig into how the buoyancy forces are formulated for the models you are using.
fluent, heat transfer in fluent, supercritical water
Adding new fluid to FLUENT for Multiphase analysis Hendrie97 Fluent Multiphase 0 March 18, 2021 06:31
ANSYS fluent and OpenFoAM comparison gentodin Main CFD Forum 6 February 26, 2021 04:58
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
Ansys Fluent analysis of heat exchanger MStudent FLUENT 2 April 20, 2015 09:40
analysis of multiphase and porous media in ansys fluent ahmed_khatibs FLUENT 0 November 4, 2014 13:01
