Intern pressure not varying even though gas is expelled from the cavity
Old   March 3, 2023, 05:23
Default Intern pressure not varying even though gas is expelled from the cavity
solene is on a distinguished road
Hi everyone,
I am facing a problem with simulating a transient flow in fluent. At t=0, the cavity is filled with helium. Pint>Pext. During the simulation, there is a mass flow rate at the outlet (exit surface of the small cylinders you can see on the picture). The problem is the following: Pressure inside the cavity (as density and temperature) remains constant. In reality it should varies since the amount of helium in the cavity is going away from it. (there is neither a creation of matter inside the cavity nor an inlet)
Do you know what is the source of this problem?
Settings:
Transient, density-based solver
Energy on, Viscous k-epsilon realizable
Helium: density=ideal gas
Everything is considered as a wall except the exit surface of cylinders (pressure outlets)
Implicit and second order method
solene is offline   Reply With Quote
cavity flow, density based, pressure, transient 3d
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 07:33
CFX Solver stopped with error when requested for backup during solver running Mfaizan CFX 40 May 13, 2016 07:50
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
