March 2, 2023, 17:54 |
Droplet detachment from moving surface
Pensylvania
I have to run a case where the droplet will detach from a moving surface/stage that follows a cosine profile. I designed a model where I defined the moving stage with a hollow in a rectangular 2d domain. I defined a UDF for controlling the stage. But my problem is the model becomes extremely computationally expensive which becomes unstable with time_step > 10^-7. The mesh size also needs to be very small ~2M mesh.
My settings: The droplet size is: 1.66 mm with a half circle hanging from top hollow moving stage. [which is not shown in the image] My questing is there any better way to do this? any other approach that can converge with a higher timestep of a larger mesh size? |
droplet, fluent, vof method |
Droplet impact on a solid surface | mwithoutm1901 | Main CFD Forum | 2 | June 25, 2016 23:17 |
body force for moving a droplet | s.amirzadeh | CFX | 3 | February 28, 2015 07:40 |
droplet model using surface tension | boesendorfer | FLOW-3D | 1 | May 22, 2014 07:21 |
how to make moving surface(flutter surface) ? | bluAero | FLUENT | 2 | November 18, 2012 15:01 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 02:10 |
