cfd
Rep Power: 15 ![]() |
I have assigned a varieble solid material property using UDF in a porous media simulations. In fact, in my UDF the density of solid material is dependent to time and temperature. My questions are:
1) How can I see the contour results of solid density in porous media. When I use density contours and also density all contours, it shows the density of fluid material in porous domain. 2) I know that C_R(c,t) returns the density of each cell. But it only considers the density of fluid in the porous media. I want to know the overall or sendity of solid in porous domain. actually I want to write a UDF that density of solid at the next step is calculated using previous density and a temperature function. |
c_r(c;t), material properties, porous media, solid material |
Thermal non-equilibrium porous media model with conjugate heat transfer | Hexahedron | FLUENT | 9 | February 22, 2023 02:55 |
How to introduce solid material and its properties at wall? | wassli | STAR-CCM+ | 3 | February 22, 2017 16:01 |
material properties of solid parts are constant ? | oozcan | FLUENT | 0 | August 2, 2016 06:04 |
Solid Properties Setup In Simulation of Porous Media | Modest Cat | FLUENT | 4 | March 26, 2012 05:00 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
