February 26, 2023, 05:51 |
Simple plate heat exchanger
Tan Yi Chen
I am trying to model a simple plate heat exchanger between air and water and a solid plate in between. However i keep getting this warning:
Warning: zone of type interior found between different fluids! Material of cell zone 7 is air, while material of cell zone 6 is water-liquid. This will adversely affect the solution. Please correct the setup. Please help |
March 1, 2023, 11:21 |
Kareem
Rep Power: 5 |
If you can post a picture of the mesh it would be helpful to give a more exact answer.
What I assume is happening is that you have an interface between two fluid domains. The interface was read into Fluent as "Interior". Find this interface, right click, and change it to a "Wall". This should solve your problem. To avoid this in the future you can name the interface in meshing as "Wall" and Fluent should automatically set it to a wall as it reads the mesh.
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
#ansysfluent, #fluent |
Fluent Heat exchanger model | gimson | FLUENT | 0 | May 10, 2021 05:30 |
a possible substitution of heat exchanger module in fluent?! | Sadegh.A | FLUENT | 0 | September 25, 2017 16:49 |
Plate heat exchanger simulation | bwt2 | FLUENT | 1 | September 14, 2017 11:38 |
Heat transfer from a heated plate using fins | pathakamit | FLUENT | 1 | April 30, 2013 05:07 |
heat transfer on dimpled plate | mech | FLUENT | 4 | February 6, 2007 16:15 |
