February 14, 2023, 02:58 |
Sixdof density problem
Furkan Enes
Rep Power: 5 |
Hello everyone,
I was trying to simulate hydraulic piston-cylinder assembly in ANSYS Fluent. I form a 2D geometry. I use triangular meshes to activate remeshing. Then, the dynamic mesh is opened in the Fluent interface and Sixdof is activated. There is a simple pressure inlet and pressure outlet so the piston goes to the outlet side. My question is that when I did not change air properties, the problem was solved correctly and converged at every step. However, when I define my oil properties, it starts to show unbelievable pressure values at the start of the calculation and then the solution diverges (Although in initialization everything seems OK in terms of pressures). I really do not understand. What can be the reason for this? By the way, the problem is with density. The change in viscosity does not lead to divergence. Does anyone have an idea? I will be glad if anyone can help me. Regards. |
divergence in fluent, dynamic mesh, fluent, sixdofsolver |
Problem regarding high density ratio(1:1000) in volume of fluid(VOF) method | j.patel | Main CFD Forum | 0 | September 17, 2013 06:25 |
estimation of density in cavitating problem | rem | Siemens | 1 | October 21, 2008 02:07 |
Negative density problem. compressible flow | Karl | Siemens | 2 | July 10, 2008 17:41 |
Problem on high density ratio in Level Set method | Kai Yan | Main CFD Forum | 10 | December 25, 2007 07:12 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
