Ansys water and air plate
Old   February 10, 2023, 05:51
Default Ansys water and air plate
Tan Yi Chen
tanyichen01 is on a distinguished road
I am currently doing a simple simulation on Ansys that is supposedly to mimick a heat rejection system. What i have is an air plate in between 2 plates of water, which looks something like in the picture. What is happening is that when i changed the air inlet humidity ratio, the air outlet humidity ratio changes, but the temperature still stays the same as other humidity ratio inlet condition. For example, when my air inlet temperature is at 34°C and inlet humidity ratio is 10g/kg, the outlet ratio is 0.0218 and air outlet temperature is 34.9°C. but when my air inlet temperature is at 34°C and inlet humidity ratio is 20g/kg, my outlet ratio is 0.027, but the temperature is still 34.9°C. Does anyone has any idea what is wrong? or is there someone that can help me with my model?
tanyichen01 is offline   Reply With Quote
#ansysfluent, #heattrasfer
Multiphase Problem with water and air over steel plate: Image attached RabiArya FLUENT 2 November 19, 2021 08:23
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 20:24
How to model a co flowing mist jet of air and water impinging on a flat plate with Eu vikash kumar singh chauha Fluent Multiphase 0 August 28, 2017 02:45
air and water mixture analysis- ANSYS CFX Suraj Marale CFX 6 March 29, 2015 06:24
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
