Steady statistics in Conjugate Heat Transfer
Old   February 7, 2023, 15:01
Unhappy Steady statistics in Conjugate Heat Transfer
Armando Diego Tomasso
arm096 is on a distinguished road
Hi all,
I am trying to realize a RANS simulation of Conjugate Heat Transfer of a combustor. Due to the oscillatory behaviour of the solution, I decided to use the steady statistics over the iteration.
When i try to process the final solution, i obtain the following problem:
areaAve(Temperature)@interface_solidside = areaAve(Temperature)@interface_fluidside
But
areaAve(Temperature.Trnavg)@interface_solidside is not equal to areaAve(Temperature.Trnavg)@interface_fluidside
Where
1.Temperature is the value of the variable at the N-iteration
2.Temperature.Trnavg is the value of the variable averaged over the N-iteration.
Can someone help me?
Thanks.
arm096 is offline   Reply With Quote
cht, steady statistics, temperature
No conjugate heat transfer between solid (cast iron) and fluid (water) part Rajaero FLUENT 5 June 25, 2023 04:07
Conjugate Heat Transfer In Porous Media gartz89 FLUENT 3 February 7, 2023 03:24
whether to use Shell conduction or Conjugate heat transfer model in Fluent Dilu CFD Freelancers 1 March 3, 2020 22:42
No conjugate heat transfer between solid (cast iron) and fluid (water) Rajaero Main CFD Forum 1 August 23, 2018 14:01
Steady conjugate heat transfer, nonsense temperature value Cagatayemre OpenFOAM Running, Solving & CFD 0 January 11, 2018 10:23
