February 7, 2023, 08:49 |
Issues in converging Solution - ANSYS Fluent
Engr. Sati Ullah
Hey Everyone, I hope you all are doing well.
Problem Statement: I simulate a stationary and fixed Pelton bucket. The bucket is hit by a slurry flow. The purpose of the simulation is to investigate the erosion in the Pelton bucket due to the presence of sand particles in the incoming water. The problem that I am going to ask for your assistance with is my solutions never converge after a couple of attempts. I have played with several parameters, which are all elaborated well below. I would request you to please share your kind suggestions for catching up on convergence after looking into the entire scenario. Geometry Description: I am simulating a Stationary Pelton Bucket, mounted to fixed support to compute sediment erosion by passing slurry flow. Water strikes the fixed bucket at 90 degrees. The bucket is enclosed in a casing (a rectangle is first sketched in Design Modeler and then extruded). A nozzle is installed at the inlet (top of the casing) to enhance the velocity. The water gets escapes after striking the bucket via the outlet (entire bottom face). A picture of geometry is attached below for a good understanding of the scenario and well-articulated coordination. https://drive.google.com/file/d/1tDu...ew?usp=sharing Meshing Details: I used hexa dominant mesh type for the casing and nozzle body and Tetrahedral for The Pelton bucket. I tried different no. of cells to catch up with solution convergence. Maximum I have tried up to 16 lakhs cells and min of one lakh in different simulation setups. I tried both physical preferences, CFD and Mechanical. Setup: I switched on the energy equation and turbulence model. I tried both K-Epsilon (2-equations, Standard, and realizable) and RSM models. Also, I switched on the DPM model to find erosion. I chose the surface injection type in DPM. I entered the same velocity in injection for sand particles as that of Fluid velocity. I run both steady and transient simulations for the said scenario. I have tried different values for residual monitoring, varying from 10^-3 to 10^-10. But the solutions do not head towards convergence in any case. Boundary Conditions: 1) velocity inlet: I chose a velocity inlet on the top face of the nozzle mounted on the top face. the velocity magnitude is 30 mps. 2) Outlet: I choose the outlet (the entire bottom face) as a pressure outlet with gauge pressure as zero. 3) The Pelton bucket is considered a No-slip, stationary wall. Dear Researchers and Scientists, I shall be highly obliged for your kind assistance/suggestions pl. |
convergence failure, convergence fluent, solution diverged |
Fluent in Ansys Workbench : Change Working Directory | sral | FLUENT | 4 | March 29, 2019 11:29 |
solution result of any parameter at all grid points in ANSYS Fluent in data file? | Muhammad Shad | FLUENT | 2 | September 25, 2018 14:02 |
Ansys Fluent .dat file loading issues | JJ O-A | FLUENT | 0 | August 10, 2017 17:43 |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 05:09 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 13:07 |
