how to set distinct pressures to different zone in fluent |
January 31, 2023, 03:28 |
jaehun LEE
Rep Power: 3 |
i am working on a shell and tube heat exchanger. below figure is the geometry that I am using. (2D axisymmetric) through the inlet of the yellow part, hot air enters (atmosphere pressure). and in the middle, there are 4 black zones. they are baffle. on the other hand, through the inlet of the purple part, cool air enters. and it's pressure is 8barG. around 9bar. (including atmosphere pressure). and between yellow and purple zone, there is a solid zone which is pipe thickness
to simulate this configuration, two distinct pressure should be applied to different zone. so i set the operating pressure as 101325 Pa, which is the same as the atmosphere pressure. and give to the outlet gauge pressure 8barG. and inlet Supersonic/Initial Gauge pressure 8barG. (as i know this value is the initial value of inlet gauge pressure). but as you can see maybe this cannot solve the problem well. this is the velocity U profile along the yellow part center line. we cannot set the operating pressure 9 bar. because between the yellow part and purple part the pressure difference is 8bar. could you give me some advice? |
ansys fluent 2019r3, gauge pressure, high pressure & velocity, operating pressure |
Error in solution using "Grid Interface" | agustinvo | FLUENT | 4 | January 20, 2015 13:03 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
Porosity profile, dividing a zone, or getting zone location from zone | khoopes | FLUENT | 0 | June 2, 2012 20:39 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 02:08 |
Fluent incident radiation problem | Michael Schwarz | Main CFD Forum | 0 | October 21, 1999 06:56 |
