setting different pressure to distinct zone
Old   January 31, 2023, 03:21
Default setting different pressure to distinct zone
jaehun LEE
jaehun LEE is on a distinguished road
i am working on a shell and tube heat exchanger. below figure is the geometry that I am using. (2D axisymmetric) through the inlet of the yellow part, hot air enters (atmosphere pressure). and in the middle, there are 4 black zones. they are baffle. on the other hand, through the inlet of the purple part, cool air enters. and it's pressure is 8barG. around 9bar. (including atmosphere pressure). and between yellow and purple zone, there is a solid zone which is pipe thickness
https://ifh.cc/v-POVQsz
to simulate this configuration, two distinct pressure should be applied to different zone. so i set the operating pressure as 101325 Pa, which is the same as the atmosphere pressure. and give to the outlet gauge pressure 8barG. and inlet Supersonic/Initial Gauge pressure 8barG. (as i know this value is the initial value of inlet gauge pressure).
https://ifh.cc/v-6ah6Zh
https://ifh.cc/v-DQwOK4
but as you can see maybe this cannot solve the problem well. this is the velocity U profile along the yellow part center line.
we cannot set the operating pressure 9 bar. because between the yellow part and purple part the pressure difference is 8bar.
could you give me some advice?
jaehun LEE is offline   Reply With Quote
ansys fluent 2019r3, gauge pressure, high pressure, operating pressure
Pressure fields in FOAM, p field, total pressure, etc. Tobi OpenFOAM Post-Processing 9 March 25, 2022 02:33
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 15:42
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
Setting up the pressure variation due to tornado in a duct(UDF)+animation guillaume1990 FLUENT 0 March 3, 2014 12:59
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
