January 29, 2023, 12:51 |
Fluent combustion
I am trying to model a jet engine combustion chamber on fluent, I have inlet mass flow rate and inlet total pressure, I am using DPM injections. For the inlet I am choosing mass flow inlet, assigning my mass flow rate and inlet static pressure at (supersonic/initial gauge pressure) and pressure opening for the outlet. In the results section I am getting the inlet pressure far higher than the pressure I assigned in the BC. How can i solve this pressure problem? thank you in advance. |
February 1, 2023, 14:13 |
Liu Wenchao
Rep Power: 5 |
Firstly, for the outlet, pressure-outlet is more recommended.
Secondly, normally, the far higher pressure is caused by the parameters you set. Check its value and unit. Good luck. |
combustion, mass flow rate inlet, pressure |
how to run fluent from matlab without using aas toolbox? | artemis96 | ANSYS | 7 | May 23, 2022 13:16 |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 10:07 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 11:54 |
Combustion SImulation in Fluent | santhosh1987 | FLUENT | 1 | May 14, 2010 17:03 |
