Duct optimization using Ansys Fluent
Old   January 29, 2023, 12:19
Default Duct optimization using Ansys Fluent
Baschi is on a distinguished road
I am trying to simulate multiple ducts through a solid using Ansys Fluent 2021 R2.
My goal is, to optimize the existing ducts, using the adjoint solver to minimize the pressure drop.
In theory, I would like to give the Solver a very basic duct geometry and let the program morph it into its optimal shape.
But I can't seem to find the optimal method of doing that,
I tried using the gradient-based solver, but the results were not satisfying, and after around 40 iterations I kept getting an error message that the mesh was not found.
I attached a series of screenshots showing the error messages I receive, maybe someone can help with the problem.
This error does not occur when I morph the geometry using the manual method.
My question is if the adjoint solver can be used to morph a basic geometry into its optimal shape and by which method I can achieve the biggest changes in the geometry.
Additionally, I would like to know if it is necessary to remesh the geometry after a few adjoint iterations, to keep the desired mesh quality.
I am thankful for every help.
Thank you in advance.
Baschi is offline   Reply With Quote
adjoint solver, duct flow, fluent, optimization, remeshing
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation Volker P. ANSYS Meshing & Geometry 22 January 17, 2012 18:27
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
