Initial Static pressure calculation
Old   January 27, 2023, 19:58
Default Initial Static pressure calculation
katwre is on a distinguished road
Hello everyone,
I am using a inlet velocity on a pipe in order to verify my pressure drop but I am not sure how Ansys calculates the Initial static pressure in order to solve the problem. Does anyone know?
Best regards
katwre is offline   Reply With Quote
Old   January 27, 2023, 20:08
Lorenzo Galieti
LoGaL is on a distinguished road
if you impose a velocity at the inlet, the inlet pressure is a result of the problem. It depends on your outlet pressure (which you impose) and the pressure drop that the CFD predicts.
LoGaL is offline   Reply With Quote
ansys, fluent
Compressible flows with larger Courant numbers Tobi OpenFOAM Running, Solving & CFD 5 February 26, 2021 16:20
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 14:47
Recursive output of Foam::word in gdb print command chengdi OpenFOAM Programming & Development 1 July 19, 2017 21:19
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
