Issues with CD Nozzle simulation in Fluent
Old   January 26, 2023, 07:23
Default Issues with CD Nozzle simulation in Fluent
Apoorv Mishra
Mishra Apoorv is on a distinguished road
I've been trying to simulate temperature distribution on a gas side chamber wall of a converging diverging rocket nozzle with cooling channels. The geometry can be seen in the image with details of the problem. I use viscous k-e turb. model. But the energy, momentum and continuity equations never converge. The residuals just oscillate about their initial position and the solver just randomly starts limiting the temperature to 5000K at faces, which is even higher than the maximum specified initial condition of 3433K. The coolant flows in an upstream reverse direction from the gas (i.e. diverging to the converging section).
I've given a polyhedra mesh with skewness 0.8 and I don't think the problem is with the mesh. The console also says 'Artificial wall on outlet or faces to prevent fluid to flow out of the boundary'. I don't understand what's going on. I understand the underlying physics of the problem though.
I am simulating 1/4th of the geometry with symmetry conditions on perpendicular walls as depicted in the problem.
Please help me out with this.
Mishra Apoorv is offline   Reply With Quote
convergance, energy convergence, fluent, nozzle analysis, rocket nozzle
Automation of boundary conditions during C-D nozzle simulation mesik FLUENT 2 December 15, 2022 13:44
CFD Simulation of a Rocket Engine Nozzle: Divergence Issue (Want to see nozzle plume) VinayakDesh FLUENT 4 February 2, 2022 21:57
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
Nozzle shock wave obtained from FLUENT simulation aerograce FLUENT 0 December 25, 2016 02:43
Fluent 2D Nozzle Simulation harman79 FLUENT 10 October 26, 2012 09:24
