Parametric Study fails because Zone Names/Interfaces need to be manually reassigned.
Old   January 23, 2023, 14:35
Unhappy Parametric Study fails because Zone Names/Interfaces need to be manually reassigned.
Bilal Hassan
Liverpool is on a distinguished road
Hey guys,
I'm a new user to the forum and ANSYS Fluent, and I'd deeply appreciate your help on this problem I've been dealing with the past week.
Case: I'm running a conjugate heat transfer problem through a pipe made of two materials flowing air through it. (think: inner material metal, outer material: insulator, central channel: air)
Problem: The simulation runs perfectly well when I simulate it in the Fluent Application, however, when I attempt to run it as a parametric study, it's not able to begin the solution for the new geometries I am simulating. I believe it is changing the geometry and corresponding named selections, but is having issues updating the mesh interface/zone names.
Specific Error Messages in Workbench are:
  • (DP 1) Mesh-operation and/or zone settings are incompatible. First resolve it manually by visiting 'File->Recorded Mesh Operations->Edit Incoming Zones... -> Match Zone Names...' .
  • (DP 1) Update of the Solution component in Copy of Steady State Fluid Flow (Fluent) for Design Point 1 failed: Update Solution Failed
  • (DP 2) The Setup component in Steady State Fluid Flow (Fluent) for Design Point 2 requires user input before it can be updated. For instructions on how to address the cell in its current state, click the blue triangle in the lower right corner of the cell in the Project Schematic. Set the design point as current to see the state at the point of failure.
Update failed for the Solution component in Copy of Steady State Fluid Flow (Fluent) for Design Point 1. Update Solution Failed
Attempts to solve:
  • Change geometry to shared topology
  • Rename Named Selections to (Walls, Inlet, Outlet, Symmetry, and Cu, Inc, and Fluid) to hope ANSYS doesn't recognize any of them as an interface
  • Reset the setup case
What I would like to happen is that I am able to specify a new pipe radius, without having to go into Fluent to update the named selections or without this error showing up.
Please help
Thanks
Liverpool FC, best FC.
Liverpool is offline   Reply With Quote
Old   January 25, 2023, 21:18
Bilal Hassan
In case anyone else runs into this problem, here is the solution:
In DesignModeler, highlight all bodies of the part, right click, and press form new part. This (according to my limited knowledge of ANSYS) turns the model into one part with three separate bodies, that allows ANSYS to use the walls as coupled interfaces, instead of having to make new mesh interfaces each time you load fluent with a new geometry.
Doesn't hurt to also share topology as well.
ansys, fluent, match zone names, mesh interface, parametric
Parametric Study - Multiple Configurations in ANSYS CFX kskong CFX 1 June 7, 2016 09:22
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Parametric Study victoryv FLUENT 3 January 31, 2013 21:29
Parametric Study Murat FloEFD, FloWorks & FloTHERM 1 October 13, 2008 04:20
